Dosbox + EMU41 problem
Message #1 Posted by Geir Isene on 29 Nov 2009, 5:18 p.m.
Running EMU41 in Dosbox under Ubuntu 09.04:
It starts and after about two seconds, on top of the bottom part (the f1 - f12 buttons) it prints out the content of the Mcode registers and on the last line it prompts "Cmd: " and with a blinking cursor.
Any takers?
Re: Dosbox + EMU41 problem
Message #2 Posted by Marcus von Cube, Germany on 29 Nov 2009, 5:40 p.m.,
in response to message #1 by Geir Isene
A "secret" debugger?
Message #3 Posted by Egan Ford on 29 Nov 2009, 8:20 p.m.,
in response to message #2 by Marcus von Cube, Germany
Nothing secret about it. It's in the EMU41 docs. Run 'emu41 /d' to get to the debugger. The prompt is 'Cmd:'. CTRL-Z from EMU41 will also dump you into the debugger. Perhaps you pressed CTRL-Z to background DOSBox but had the focus on DOSBox.
This is unrelated to DOSBox. IIRC, corrupt ROM images can also dump you into the EMU41 debugger. Try a fresh install of EMU41.
Edited: 29 Nov 2009, 8:21 p.m.
Message #4 Posted by Geir Isene on 30 Nov 2009, 5:57 a.m.,
in response to message #3 by Egan Ford
That fixed it. Thanks.
