Re: Direct current circuit analysis program Message #2 Posted by Vieira, Luiz C. (Brazil) on 9 Nov 2009, 8:49 p.m., in response to message #1 by ferroburak
Hi, Ferroburak;
I do not know the Circuit4 program (any source of information?), but based on the fact that you are an aerospace engineering student, I would like to ask what sort of resource you would need in a DC analysis program. I mean, will you enter a circuit description based on nodes/mash, the kind of active(source)/passive(load) component and their location and solve for current/voltage unknowns? There are many programs that might fill your needs here, if you are searching for HP49/HP50 application programs. If you want to go ahead with Electrical Engineering for these calculators, try here, too.
Hope this helps.
Luiz (Brazil)
Edited: 9 Nov 2009, 8:49 p.m.
