DeSoldering SMD Components easily!!! - Chipquik Message #1 Posted by Thomas Chrapkiewicz on 31 Oct 2009, 10:49 p.m.
I have not yet tried this stuff, but the videos show it makes removing even 4-sided SMD components very easy!!!
It's a low temperature - high heat retentivity solder that stays liquified while you can heat up all four sides of smd component to then slide it off!!!
http://www.chipquikinc.com/index.htm
R,
TomC
