Re: HP9835 system Message #2 Posted by Steve Leibson on 1 Nov 2009, 9:59 p.m., in response to message #1 by Bo in Lund (SE)
Bo, your HP 9835 came from HP in Colorado, where I used to work. The minicartridge drive likely has suffered "gummy capstan" aging, where the rubber on the capstan has turned to goo. In addition, any old tapes you have likely have died as the adhesion is lost between the mylar backing and the oxide coating that stores the magnetic bits. That said, you can get the drive revived if you want. Take a look here if you're interested.
Edited: 1 Nov 2009, 10:00 p.m.
