Re: HP 17BII+ BUG Message #3 Posted by nacho on 22 Oct 2009, 8:12 a.m., in response to message #2 by Don Shepherd
Hello Don,
try that:
Go to Time menu.
Select APPT Menu.
Select for example APT1: then enter a date ( must be the same day for example today 22 and an hour )
Then You will see SET:1
OK, go to main menu...no ERROR answer when 1 INPUT 0 / done...
Go to Math menu and Press PI key and then N! to create an error...
It will return N! N<0 or N NONINTEGER
Then press 1 or 2 or one number KEY... it will activate the appointment and alarm will sound...
Hope it is better explained
nacho
