Connecting HP-110 to a 9122D floppy drive Message #1 Posted by John AS (UK) on 17 Oct 2009, 6:18 p.m.
I have the following set-up:
HP-110 laptop (HP-IL interface)
HP 82169A HP-IL / HP-IB interface
HP 9122D floppy drive (HP-IB interface / SS-80 protocol)
This set-up works fine and allowed me to format floppies and read-write them. I think the combination of the 82169A + 9122D works the same as the 9114A/B HP-IL floppy drive.
I've also tried the HP-110+ (Portable Plus) laptop and that worked fine too. I had no luck attempting to use an Amigo floppy drive (9121D).
The 82169A has a serial number starting 2512A, the 110+ plus manual states:
"Note: If you intend to use HP-IB disk drives, the HP-IL/HP-IB interface must have a serial number greater than 2406A00000. Otherwise it will cause a bad unit error message."
I've got a friend with an HP-41 and HP-IL interface, I'll report back if this can drive the 82169A + 9122D as well.
