Help with credits in the book, please. Message #1 Posted by Geoff Quickfall on 16 Oct 2009, 7:12 p.m.
Hello all!
The book is comming along well, of course that is a subjective opinion since I have never written something this large for publication.
Just finished the Pioneer and Stretch Pioneer chapter which gives the following examples:
1. HP 48SX with non functional display and keyboard
2. HP 42S with non functional display, keyboard and the memory
upgrade.
Here are some unlabled pictures of the 42S restoration and memory upgrade. All this thanks to Tony Duells' postings and emails. The book has many more figures, each referred to in the text and much more helpful then what is pictured below.
Removing the keyboard overlay for access to the four heat stakes.
Two keyboard overlays, one with the adhesive and curved from
removal, the other with the adhesive removed and reshaped by placing between two vinyl sheets and flattening with a spoon.
Close up of the heat stakes before drilling.
Close up of the heat stakes after drilling.
The deteriorated keyboard flex PCB foam insert. The major cause
of the failed keyboards on the Pioneers and Stretch Pioneers.
Jumper desoldered showing the trace bridge left after the solder
was removed
Close up of the jumper with the trace bridge removed and new jumper
in place.
New memory accessable!
_______________________________
Now for the reason and title of the post. There are THOUSANDS of postings in the archives ;-). Also articles and repair sections of the museum, let along googling the internet for repair techniques.
I certainly do not want to step on any feet when it comes to credit for techniques that have been developed. With that in mind I am compiling a list of peoples names that seem to be the originators of various techniques.
Some obvious names come to mind:
1. Katie Wasserman and the HP-97 topcat printer gear replacement
2. Tony Duell and the increase of RAM for the HP42s
Tony also came up with a milled brass pinch roller for the 41C!
3. Diego Diazs' flex PCB replacement for HP 41C I/O assembly.
But some are not so obvious:
3. Vinyl tubing for pinch roller
4. Dampening couple using wire insulation
5. Jumper position in the Spice for decimal versus comma separator
6. Foam insert replacements for Pioneers.
7. Just saw Luizs' spice wire work around for broken flex PCB
8. Using vinyl envelopes to smooth out labels that have been
removed from the backs of the Classics and others.
9. First occurrence of the quartz crystal application to the
HP-45.
10. LED block replacements for removing ghosting. Did this one
after reading the forum and resurrected an HP-45 and HP-80.
The problem is the proper crediting of techniques. Of course a blanket THANK YOU would suffice but I rather be more personal.
For those of you wondering why the book is taking a while; it is going to be 300-400 pages with over 250 figures. It encompasses all the techniques that have been published (hopefully).
I am, however, documenting ALL the restorations in house and this takes time. For example, I need a Spike for photo purposes. I have one being lent to me but I have to get to London to pick it up (thanks Wlodek).
As you see above, I just finished upgrading 3 HP-42S to 32K. Two were non functional off Ebay and once I had documented the successful conversion I then upgraded my HP-42s that I use along with my HP-41C.
So does anyone know who originated the following:
1. Vinyl tubing for pinch roller.
2. Dampening couple using wire insulation.
3. Jumper position in the Spice for decimal versus comma separator
4. Foam insert replacements for Pioneers.
5. Just saw Luizs' spice wire work around for broken flex PCB.
6. Using vinyl envelopes to smooth out labels that have been
7. First occurrence of the quartz crystal application to the
HP-45.
8. LED block replacements for removing ghosting. Did this one
Cheers, Geoff
Edited: 16 Oct 2009, 7:14 p.m.
