Re: Spec of dust in a 16C LCD screen Message #3 Posted by R.J. Soto on 15 Oct 2009, 1:02 p.m., in response to message #2 by Geoff Quickfall
Hi Geoff,
Thanks for your very detailed explanation. I had the notion that even removing the back of one of these calculators was a destructive process to some degree. I'm glad to know I was mistaken. I will first try Jimi's approach, and if that doesn't work, then I will do it your way. I'm sure either way it should work.
Out of curiosity, since you sound very confident about this procedure, I assume you have performed it before. Did you do it on a 16C, or in one of the other models?
Many thanks,
Ruben
