Woodstock feet replacements?
Message #1 Posted by Michael Meyer on 7 Oct 2009, 11:37 a.m.
Now that my Woodstocks are getting older, the feet are getting to the point that just "sanding" them isn't working... as with the drive wheels, they're turning into sticky goo.
I have had no problem finding the tan rubber in furniture feet, but cutting them into little Woodstock feet is turning out to be more difficult than I expected. They end up the wrong size, the wrong angles (the rubber deforms when pressed on with a knife), etc.
Any ideas on how to cut uniform replacements?
Re: Woodstock feet replacements?
Message #2 Posted by Rainer Wiedemann (Germany) on 8 Oct 2009, 6:20 p.m.,
in response to message #1 by Michael Meyer
It may be helpful keeping the rubber in a freezer overnight. It probably won't deform when you cut it due to its frozen state.
I never tried that on my own, the idea spontaneously came to my mind, so it might not work.
Good luck.
Message #3 Posted by Michael Meyer on 9 Oct 2009, 1:00 a.m.,
in response to message #2 by Rainer Wiedemann (Germany)
Thanks. I knew somebody had to have SOME ideas. I thought of cutting razor blades to build a box die cutter, but I've never done something like this. The feet have to have depth and a taper unless they are glued towards the surface, but that would change the way you access the screws. I guess another approach would be to fill the openings with another material and just top them off with the rubber part. Still... a replacement piece would be best.
maybe a mold to fill with hot glue, topped by rubber?
Message #4 Posted by Vieira, Luiz C. (Brazil) on 9 Oct 2009, 1:30 a.m.,
in response to message #3 by Michael Meyer
Hi, Doc; are you OK?
I read your post and wondered about it since; no ideas so far. The specific format of the rubber feet actually helps cutting a spare from raw material (they are like small bricks). And the mold with hot glue seems valid: just wrap an existing feet with any aluminum foil (thicker than the one used in the kitchen, which is as thin as a paper) and remove the feet from the top: your mold is ready. You could also try to carve the glue bar directly and then use a small amount of hot glue to set the sheet rubber feet (flat cut) in place. I would also suggest to cut the new rubber feet (sheet) a bit larger than the actual feet so its edges match the thickness of the small borders around them in the calculator case. Wish I had a picture or a Chinese to write down its description in a thousand words...
Success!
Luiz (Brazil)
Message #5 Posted by Andreas Grund on 9 Oct 2009, 1:58 a.m.,
in response to message #4 by Vieira, Luiz C. (Brazil)
The idea of Luiz how to build a simple mold is great, however, instead of hot glue I would prefer a 2K-silicon compound, which certainly can be blended with a filler and/or tan pigment to get the right hardness and surface. Such silicon compounds are usually available at modelling shops or dental supplies.
Andreas
Message #6 Posted by Karl Schneider on 9 Oct 2009, 2:39 a.m.,
Hi, Luiz, and let me add my belated welcome upon your return from hiatus!
I admit to not quite getting the reference, there -- does this refer to a calligrapher painstakingly producing an illustration 'worth a thousand words'?
-- KS
Edited: 9 Oct 2009, 2:40 a.m.
Message #7 Posted by Vieira, Luiz C. (Brazil) on 9 Oct 2009, 5:15 a.m.,
in response to message #6 by Karl Schneider
Hi, Karl;
Yeap, you are correct about the 'chinese thought'. It was just a reference of the origin of the thought (at least, I've been told that since I was a kid...) because after reading what I wrote, I felt as using too much words and failing to describe it... Frustrating.
Cheers and thanks for your welcome. I appreciate.
Luiz (Brazil)
Edited: 9 Oct 2009, 5:30 a.m.
