Re: Connecting HP 48GX with PC via Conn4x....help!!! Message #2 Posted by Vieira, Luiz C. (Brazil) on 5 Oct 2009, 11:01 a.m., in response to message #1 by juan demin
Hola, Juan; que tal?
If you are using an HP48GX, the only port available with its hardware is RS-232 compatible (PC_compatible serial) and, if I am not wrong, it is possible to use a serial-USB converter (that should not be the problem). But I am not 100% sure about this...
If you have the chance, try using another computer with a RS-232C compatible serial port just to make sure your HP48GX connects correctly.
(after editing) I forgot to ask: the keystroke sequence you mention, is it correct? I cannot check now, but it seems to me it has more keystrokes than usual (maybe it is because I´ve been using the HP50G more, lately)
Success!
Luiz (Brazil)
Edited: 5 Oct 2009, 12:52 p.m.
