Re: Have you tried.. (Re: HP49G+ doesn't turn on) Message #3 Posted by Pal G. on 1 Oct 2009, 2:05 p.m., in response to message #2 by Vieira, Luiz C. (Brazil)
Mine is bricked too. When I press the RESET button, with a small paperclip, I see a solid line that stretches across the screen, and sometimes an individual annunciator comes on (alpha, left-shift, etc) . Then, upon release of RESET, the LCD is dimly on, but does not respond to ON+plus or ON-minus. Reth's ON+C (release) CLEAR does not work either. I don't see Metakernal splash screen or anything anymore.
I've pulled all batteries for 24 hours. Nothing. I am using good batteries.
I was just programming some userrpl two days ago when it first locked up. I rebooted once or twice, but now it seems terminal.
