HPGCC and Steamtable Calculations (IF97) Message #1 Posted by Jan Kromhout on 7 Sept 2009, 12:53 p.m.
I have transfered the Steamtable calculation IAPWS-IF97(as you can find on several places on the net) to small subroutines (functions)
With these functios I created the calculations (executable). On this moment I have finished 10 small executables for the HP50g.
Every module is tested with HPAPINE. I love this tool because every time sending the finished routine to the HP and test it cost a lot of time!
I have two questions.
1. When I created to big functions the S->EXE aborts on amount of memmory (I have no programs on the HP). Is it posible to create these exe outside the HP50G.
2. Is the memmory on the SD card seen as physical memmory? Supose I have an programm greater than then the memmory of the HP and stored on the SD Card, can it running?
Thanks in advance.
Jan Kromhout
Hellevoetsluis-NL
