Re: HP-48 Connectivity Kit Message #7 Posted by JJB299 on 30 Aug 2009, 1:17 p.m., in response to message #1 by Karl-Ludwig Butte
If you have an old 56k modem installed, it may be hogging up the COM1 port.
Try freeing up your COM1 port first:
Start > Settings > Control Panel > System
In System Properties, select the "Hardware" Tab.
On the Hardware Tab, select "Device Manager" button.
In Device Manager, scroll down to the "Modems". Open up the modems list view.
Right click on any modem (and any communications cable) and select "Disable".
While your there, go to the "Ports".
Right click on the Communications Port (COM1) and select Properties.
Make sure the port settings match the settings in the Connectivity Kit. You should use the HP Connectivity Kit 3.0 free from HP.
Hope this helps.
