HP and Bendix and the Canadian Quickie, any other weird applications for HP out there? Message #5 Posted by Geoff Quickfall on 5 Aug 2009, 1:02 p.m., in response to message #2 by Geoff Quickfall
I must say it would certainly be interesting to have the complete unit for 1500 (not that it is in my budget). But the actual Bendix colour display, the interpreter for generating alpha characters on the HP-67 and the HP-67.
I remember seeing and bidding on an alpha generator for the HP-67. The seller did not know what it was intended for and did not have the instructions for accessing keys. From what I read on the current auction the sheet of paper posting indicates that a through Z can be accessed by a series of key pushes. The alpha code can be scanned onto a card and used as "alpha" prompts for data input.
Pretty slick, an alpha numeric HP-67, MY DREAM MACHINE!
I remember being at an air show in 1986. There was an aircraft with a large canard called the Canadian Quickie (no relation!).
Canadian Quickie
In the cockpit was an HP 41CX which sat in a cradle and was hardwired through a modified module to the digital Bendix dashboard (all LEDS). This allowed the HP to access the digital data from the aircraft sensors, OAT, IAS, TAS, Temp, Altitude and etc. It provided the pilot with an flight dynamic management system.
Cheers All, Geoff
Edited: 5 Aug 2009, 1:30 p.m.
