Re: BATTERY LONGEVITY Message #3 Posted by DaveJ on 27 July 2009, 4:40 a.m., in response to message #1 by Howard Lazerson
I use an 11c daily and the batteries last forever [ well at least it seems that way ]. Is that true for the newer 12c?
No, absolutely not. See HERE and HERE
The 20B with the same basic architecture is rated for a battery life of around 9 months, Cyrille has implied the new 12C should be a bit better than this this. That's the general figure HP quote.
But it could be as low as a few months if you really used it hard.
Technically speaking, if you had a program loop running continuously (Katie gives an example of a "long amortization function"), the batteries would be dead within 20 hours. And that's being generous, that figure does not include various losses.
Dave.
