Re: More on the new 12C Message #17 Posted by Katie Wasserman on 25 July 2009, 11:51 p.m., in response to message #16 by Eric Smith
Surprisingly current consumption has increased a bit with the latest firmware. I had made earlier measurements and posted to this forum and I've now re-tested using the exact same setup and confirmed on two different 12C+ calculators.
Here's what I found:
Condition Old firmware New firmware
power off 4uA 4uA
power on, static display,
no keystrokes 45uA 45uA
continuous keystrokes
(number entry) 1mA 2mA
long amortization function 15mA 20mA
tight program loop 15mA 20mA
continuous self-test ([ON]+[+]): 4mA 12mA
extended test modes
([ON]+[g] and [ON]+[g]+[ENTER])
static display 1.8mA 2.5mA
When running, the average clock speed must be higher, a lot higher when running the continuous self test. I say average clock speed because I believe that the firmware frequently changes the clock speed.
Cyrille and Eric, do these current measurements make sense to you?
Thanks,
Katie
Edited: 25 July 2009, 11:52 p.m.
