HP 50G LCD problem Message #1 Posted by macbxx on 28 June 2009, 6:47 p.m.
I bought a used 50G, and was testing and did a soft reset, only to find the previous owner had installed a password application(SDP 2.2, good program). Instead of calling him, I tried to reset it multiple times, and at last left it without batteries overnight. Since it didn't work, I just called the seller like I should have from the beginning, and the password worked, but now I have a row of "dead" pixels in the middle of the soft menu. I don't think they're really dead, since making a vertical line in the graph window makes the pixels show, but nothing else makes them work. Could I fix it changing the lcd, or is the cause something else? Thank you.
