SPICE question - repost Message #1 Posted by Michael de Estrada on 26 June 2009, 9:56 p.m.
I asked this question previously, but received no replies, so I'm going to try again. I know somebody knows the answer.
I am quite familiar with the construction and repair of Spice type 1 series calculators (HP3xE/C) with the un-soldered press-fit design, having fully disassembled/reassembled 8 different units. Most of the "repairs" have consisted of swapping interchangeable parts from different units. One of the most common problems is broken/damaged battery contacts and/or charger circuit board traces. Another less common problem is a damaged ribbon connector between the contacts board and the power circuitry board. On the Spice Type 1 series, the battery/charger contact assembly terminates at a ribbon connector extension to the power circuitry board, which is press-fit to the main circuit board. Therefore, it is possible to swap a bad assembly with a good one sourced from a different calculator.
My question is whether this is possible with the later type 2 series with the soldered construction, or is the battery/charger contact assembly integral with the main circuit board?
Thank you for your assistance,
Michael
