Re: Fixed; directions here Message #10 Posted by htom trites jr on 16 June 2009, 1:48 p.m., in response to message #9 by Thomas Okken
Quoting from http://fitaly.com/fitalyvirtual3/readthisfirst.htm
T3 Dynamic Input Area libraries
FitalyVirtual requires the presence of two libraries — AppSlipRotate.prc and StatusBarLib.prc — for the Dynamic Input Area of the Tungsten T3 to work properly. Installing these libraries will override built-in ROM libraries and will require that you do a Reset at the end of the Hotsync. (This is normal and does not cause any data loss. It only occurs once when you install these libraries.)
These libraries are provided by PalmOne who endorses their use. You may find other third-party applications also asking you to install these same libraries but you only need to do it once. Note that reinstalling them does no harm: the Hotsync log will include a message telling you that they are already present. Finally, if you attempt to enable FitalyVirtual without having installed these libraries, enabling will fail and you will get a warning message asking you to install them.
These libraries should never be installed on a T5 or a LifeDrive.
The other places I've seen the files have similar messages; provided by PalmOne, needed on T3, dire results if they are installed on any other Palm, or if they are not installed together. Finding "official" news about these is difficult, at least for me. If you have access to the old Palm developer docs you might find some info there.
I hot-synced, dragged the two into the install box, hot-synced, got a soft-reset, opened Free42, and it was working.
http://www.handshigh.com/html/tungstent3.html
http://www.red-mercury.com/t3.html
are two other sites with similar info. Seems the T3 shipped without something, and for some reason they didn't put it into the flash update that came along later.
Edited: 16 June 2009, 1:55 p.m.
