Re: Fast editor for 48SX/GX?? Message #3 Posted by Mark Edmonds on 24 May 2009, 6:18 a.m., in response to message #2 by Chris Foley
Thanks Chris :)
I've got that installed and trying it out. Shame you can't enter programs exactly the same way you can in the built-in editor (a few quirks I've found so far) but old habits die hard.
Not too impressed with how long it takes to load a large program though.
For a prog I am working on now that is about 7K big, loading it into the built-in editor takes 41 seconds on a 48G and 45 seconds on a 48GX. Odd as I thought the GX had a faster CPU.
Using StringWriter, it still takes 41 seconds on a GX. However, scrolling in SW is massively faster!
So despite the loading time, SW is obviously a huge step-up from the built-in editor. Thanks for the recommendation :)
Mark
You should try StringWriter from JYA.
It is very fast and easy to use. It is close to the version available in the 49+.
You can DL it at this address :
http://www.hpcalc.org/details.php?id=129
Good programming ;-).
Chris
