Contamination??? probably... Message #2 Posted by Geoff Quickfall on 11 May 2009, 12:35 p.m., in response to message #1 by Michael Lopez
I had the same problem on two restorations. Both had positive clicks but failed to register the key input.
One was the on/off rocker arm similar to you alpha key and the other calculator had 3 of the digit keys not registering. The keyboards were in excellent condition.
Try the following, get an eye dropper and place a drop of water on the offending key. Work the key back and forth numerous times. Blot the water off and then add a drop of alcohol, repeat the key exercise. Let dry and try the keys. I use a lens cleaner bulb blower to force air around the key when drying.
If it does respond, or does not, the next step and with nothing to lose, dis-assemble the calculator; i.e. remove the back case, then remove the PCB and the zebra strip from the keyboard.
During the following, keep the LCD above the level of the liquid.
- Get a tall glass wide enough to accept the keyboard upright.
Fill with luke warm mildly soapy water to BELOW the level of the
LCD panel. Insert the keyboard and let soak. Agitate the water
by stirring or by subsequent and repeated removals of the
keyboard out of and back into the water. The intent is to
remove any sugar based or sticky water soluble material from the
keyboard contacts.
- If you suspect corrosion as indicated by leaky batteries or blue
corrosion on some of the contacts then using the same glass,
rinse the keyboard in dilute white vinegar.
- I then rinse the keyboard in the glass with water, using the
same method.
- Next rinse with alcohol in the same manner.
- Air dry or use a drying box to accelerate the drying proceedure.
(see photo below)
-Re-assemble and try it out.
1 The soapy water will remove non conductive oil based, sugar
based (coffee spill, sherry!!) as well as particulate
contamination.
2 The vinegar will dissolve the corrosion due to outgassing
batteries.
3 The water rinse will also remove sugar based contaminants,
particulate matter and soap residue.
4 The alcohol removes or mixes with remaining water and will help
in the drying process
THIS HAIR DRYER HAS A "COLD" SETTING, no heat applied!!!
