Re: HP71B PCB interconnection strip Message #3 Posted by Tony de Groot on 5 May 2009, 8:54 a.m., in response to message #2 by Etienne Victoria
Hi Etienne,
Thank you for the very detailed reply. This definitely looks possible, however I prefer to repair in a way that keeps the same functionality and operation, so will try to avoid soldering for the moment.
I was thinking about maybe getting some very fine gold wire (maybe from a jeweller) and setting up a row of pins to get the right spacing and winding the wire backwards and forwards to get the array of wires, then using something like adhesive tape to hold it in place, trim the ends to remove the short circuits, and then replace the original zebra strip with that. How to stop the tape from sticking to the holder is something I have not worked out yet.
Just had another thought that maybe I could wind the wire around the flexible strip and cut along it to form a set of wire segments.
I am assuming that the zebra strip used for LCDs are of too high a resistance to work correctly as a substitute, but I was wondering if anyone had tried that already?
Thanks,
Tony.
