Re: HP-25C strange behaviour Message #3 Posted by Geoff Quickfall on 22 Apr 2009, 12:51 p.m., in response to message #1 by Alberto Fenini
Hello Alberto
Michael is absolutely correct, it should be a minor keyboard cleaning problem.
In the case of your #4 key, sometimes a conductive dust or battery corrosion precipitate can short the keyboard. What happens is two traces from two keys can connect and the logic input sent to the keyboard processor is recognized as the wrong key input.
In the case of your #1, either it is a non-conductive piece of debris or broken dome that creates the 'click' sound and creates the contact. The broken dome problem is not easily fixable but you can determine if the dome is broken by the sound and feel. They should be identical to the other working keys.
Another problem on the keyboard is that the keyboard processor is not processing the info due to a bad connection at the chip itself, again due to conductive debris or corrosion.
When cleaning the keyboard use water to dissolve any sugar residue such as spilt beer or wine or pop. Then rinse with Michael's vinegar solution. Then rinse with 90% alcohol. I personally use an ambient air drying box. That is, a shoe box with an hair dryer attached to one end as in the picture. The hair dryer is set to COLD causing only room temperature air to pass over the keyboard and PCB.
Shoe box:
[/pre]
In conclusion:
1. remove the PCB from the Keyboard
2. remove the LED panel from the PCB
3. soak both the PCB and the Keyboard in warm (not hot) dilute
water.
4. rinse
5. soak both PCB and Keyboard in dilute vinegar
6. rinse
7a. dry the units (I prefer ambient air temperature as my
controls are not that accurate and there is actual airflow
penetrating the units cracks and crevaces)
7b. while drying your keyboard do not wipe the front dry. Dab it
dry with a soft cloth. The Woodstock silk screening is
notorious for comming off. This is due to the Clear Laqueur
finish decomposing from UV rays over the last 30 years.
8. assemble and test.
As a last resort, but very safe, I use a citrus based adhesive remover found at your local electronics shop. I have some HP 15C that have been working perfectly (Really, perfectly) with respect to the keyboards after using the above method and finishing it with the citrus adhesive remover. It is safe for the silkscreening and internal keyboard components.
On the reverse side of the keyboard you will see holes corresponding with the centre of the keys. A quick spray of the cirtrus oil in the offending keys hole will invariably solve the contact, and key bouncing problems.
This link to an old post might be helpful.
