Yes, Message #3 Posted by Geoff Quickfall on 22 Apr 2009, 12:57 p.m., in response to message #1 by Sean Connor
Sean;
do you have a laser printer or ink jet, not that it matters, The product you are looking for is an adhesive back clear printable sheet for your printer.
Take a plane sheet of paper and work out your labels using the correct font. Create your overlay using font sizes and spacing that will match the keyboard correctly.
Then, once you are happy with the outcome, print off a the overlay on the adhesive clear sheet. Slice the sheet in horizontal rows, of the correct thickness and place over your blank overlay.
It should look like this:
