Re: HP 50G user manual Message #2 Posted by Michael de Estrada on 15 Apr 2009, 1:57 a.m., in response to message #1 by hpnut
1. Yes. Once the menu item is selected, the stack entry is automatic. If you then type ENTER, you duplicate the entry. The manual is incorrect.
2. You cannot convert Watts to BTUs. Watts are units of Power and BTUs are units of Energy. Again this is simply an error in the manual. Note that the example is actually a coversion between Watts and horsepower(hp), which is correct since they are both units of power. Also, they make this coversion much too complicated. Assuming you are operating in RPN mode, all you need to do is type:
33 W <left shift> hp
and you get the same result. No need to enter all this stuff into the stack and then use the Convert function.
The HP-50g is a magnificent device with mediocre documentation.
Michael
Edited: 15 Apr 2009, 1:59 a.m.
