Re: Can an HP 50g print via IR port? Message #2 Posted by Mike Morrow on 1 Mar 2009, 10:30 a.m., in response to message #1 by Michael de Estrada
Yes. AFAIK, the HP82240 printer is the ONLY one supported by the HP50g for printing, even though it is no longer sold. The B version is default, but the older A version can be used with support of the OLDPRT command.
The CAT function will show you a lot of recognizable print commands starting with PRxxx (but most listed PRxxx commands are not printer related).
If you download the HP50g User Manual and the HP49g+ Advanced User Reference, then search the pdf file for "print", you'll see all that's available.
The IR output range of the HP50g is very very short, so try again with the IR ports aligned very closely.
Edited: 1 Mar 2009, 10:45 a.m.
