Can we beat the 5.81 hours on the TI95 with the HP71B? Gene, Yes we can! Message #1 Posted by Egan Ford on 28 Feb 2009, 5:13 p.m.
This question was originally ask by Gene in the following post: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=53988:
Gene: This is a write-up I just received from Palmer Hanson, who edited the TI PPC Notes for many years in the 1980s - early 1990s. Thought it might be interesting. Looks like the race to 1000 digits on a machine prior to 1990 now belongs to TI? Can we beat the 5.81 hours on the TI95 with the HP71B? :-)
I was not a member of this fine forum at the time of this post. But its never too late (just under 5 years late).
I wrote a spigot program in FORTH and ran it on my 71B this morning. I selected the spigot algorithm for the following reasons:
- Spigot programs are very small. Mine is 2x larger because I unrolled the first outer loop. This avoids a conditional statement in the inner loop. Consider the initial loop a method to initialize the array A.
- This spigot algorithm requires integers only. A benefit for FORTH.
- Spigot programs allow you to watch the action. No need to wait for the final result.
Output:
3141592653589793238462643383279502884197169399375105820974944592307816406286
2089986280348253421170679821480865132823066470938446095505822317253594081284
8111745028410270193852110555964462294895493038196442881097566593344612847564
8233786783165271201909145648566923460348610454326648213393607260249141273724
5870066063155881748815209209628292540917153643678925903600113305305488204665
2138414695194151160943305727036575959195309218611738193261179310511854807446
2379962749567351885752724891227938183011949129833673362440656643086021394946
3952247371907021798609437027705392171762931767523846748184676694051320005681
2714526356082778577134275778960917363717872146844090122495343014654958537105
0792279689258923542019956112129021960864034418159813629774771309960518707211
3499999983729780499510597317328160963185950244594553469083026425223082533446
8503526193118817101000313783875288658753320838142061717766914730359825349042
8755468731159562863882353787593751957781857780532171226806613001927876611195
909216420198
TIME: 11362.03 SEC
1000 digits in 3.16 hours. Almost 2x faster than the TI95. Over 2x faster than BASIC versions in the aforementioned thread.
Code (my first attempt, more optimization can be done):
: SPIGOT ;
: 04D. <# # # # # #> TYPE ;
: DUM* DUP ROT ROT UM* SWAP 2SWAP UM* D+ ;
1000 CONSTANT N
N 4 / 14 * CONSTANT M
5 CONSTANT S
CREATE A M S * NALLOT
VARIABLE B
VARIABLE C
VARIABLE E
10000 CONSTANT F
VARIABLE K
76 4 / CONSTANT MAXL
M DUP B ! C ! 1 K !
: SPIGOTM
0,
BEGIN B @ 1 - DUP B ! 0 > WHILE
B @ DUM*
20000000,
D+
B @ 2* 1 -
M/MOD
ROT
A B @ S * + !
REPEAT
F M/MOD 04D.
DUP E ! 0
BEGIN C @ 14 - DUP DUP C ! B ! 0 > WHILE
B @ DUM*
A B @ S * + @ F UM*
D+
B @ 2* 1 -
M/MOD
ROT
A B @ S * + !
REPEAT
F M/MOD E @ 0 D+ 04D.
DUP E ! 0
1 K +! K @ MAXL = IF CR 0 K ! THEN
REPEAT
: DOIT
CLOCK
SPIGOTM 2DROP CR CR
." TIME: " CLOCK X<>Y F- STD F. ." SEC" CR
Original C program:
#include <stdio.h>
#define NDIGITS 1000
#define LEN (NDIGITS/4+1)*14
int main()
int a[LEN];
int b;
int c = LEN;
int d = 0;
int e = 0;
int f = 10000;
int g;
int h = 0;
while ((b = c -= 14) > 0) {
while (--b > 0) {
d *= b;
if (h == 0)
d += 2000 * f;
else
d += a[b] * f;
g = b + b - 1;
a[b] = d % g;
d /= g;
printf("%04d", e + d / f);
d = e = d % f;
h = 4;
return (0);
More spigot info:
http://sense.net/~egan/hpgcc/#Spigot%20Algorithm.
Edited: 28 Feb 2009, 5:35 p.m.
