Printing on a 82143A with HP-75C Message #1 Posted by Giovanni Jimenez on 27 Feb 2009, 4:19 p.m.
I am wondering if I could print on a HP-82143A printer from a HP-75C. The original printer (82162A )for the HP-75C looks identical to the 82143A, except of course for the connector. So how do I map the 7 pins of the 82143A to the 4 pins (2 IN and 2 OUT) of the 82162A?
Can I even do that ? do the signals use the same voltage levels?
I assume so as they are both HP-IL, right ?
Thank you!
Giovanni
