HP 35s Bubble Sort Message #1 Posted by Elliott W Jackson on 14 Feb 2009, 12:12 a.m.
The Wiki site claims the Gnome Sort to be the simplest, but it turns out that converting the Bubble Sort to HP GTO-ese is actually simpler, and has faster run times too.
Pseudo code:
procedure bubbleSort( A : list of sortable items ) defined as:
n := length( A )
do
swapped := false
n := n - 1
for each i in 0 to n - 1 inclusive do:
if A[ i ] > A[ i + 1 ] then
swap( A[ i ], A[ i + 1 ] )
swapped := true
end if
end for
while swapped
end procedure
Program listing:
S001 LBL S
S002 STO Z bbb.eee
S003 CF 0 start of do-while
S004 0.001
S005 STO- Z bbb.(eee - 1)
S006 RCL Z
S007 STO I for (I = bbb; I <= eee - 1; i++)
S008 RCL I
S009 1
S010 +
S011 STO J
S012 RCL(J) A[i+1]
S013 RCL(I) A[i]
S014 x<=y?
S015 GTO S020
S016 STO(J) A[i+1] = A[i]
S017 RDN
S018 STO(I) A[i] = A[i+1]
S019 SF 0 swapped = true
S020 ISG I
S021 GTO S008
S022 FS? 0 swapped = true?
S023 GTO S003
S024 RTN
LN=78 CK=B7E4
And finally, some timings:
21 registers, 10.030: 23 seconds
21 registers, 10.030: 24 seconds
101 registers, 10.110: ~10 minutes
So, even the much-detested Bubble Sort is superior to the cutesy Gnome Sort I started this project with.
