Re: HP48Gii SWAP Message #2 Posted by Jeff O. on 12 Jan 2009, 7:40 a.m., in response to message #1 by V Green
Press the right-cursor (not right-shift) button to perform the swap function (unless you're doing something where it would make sense for it to move the cursor to the right, of course)
There is a ROLL function on the 48Gii (press TOOL, STACK, NXT), but it behaves differently from the ROLL function on RPN calculators. Since the stack is not limited, you must tell it how many levels you wish to roll. Also, ROLL actually does a roll-up. Use ROLLD to roll-down. Pressing DEPTH ROLLD will perform the closest thing to the RPN roll-down function.
edit - I should have stated that I am far from an expert in the operation of RPL machines, and that others would probably provide more, better and/or corrected information.
Edited: 12 Jan 2009, 12:23 p.m. after one or more responses were posted
