Re: Size of Flash memory in 50g ??? Message #2 Posted by MikeO on 6 Jan 2009, 12:41 a.m., in response to message #1 by Klaus Boehme
On my 50g, there are a couple libraries on port 2:FLASH for the Equation Library. These came pre-installed. Remaining memory on mine for port 2 shows as 699KB according to the file manager (WHITE Key then "APPS" or "APPS" key then select item 7).
Top level listing on mine:
0:IRAM 227KB
1:ERAM 127KB
2:FLASH 699KB
3:SD 934560KB
Home 227KB
-Flight
-Calc
-Trig
-Spen
You can examine objects stored in flash using the file manager - use up/down arrows to select "2:FLASH" and press ENTER.
My listing for 2:FLASH looks like this:
EQLIB:Equation L226 57496
EQLIB:Equation L227 11307
