Re: Op-Amp Gain and Offset Design for the HP-67 Message #4 Posted by Stefan Vorkoetter on 5 Dec 2008, 1:44 p.m., in response to message #3 by Prabhu Bhooplapur
There was a time when any electronic circuit was conceived with op-amps.
Many still are. Even with the trend to do signal processing digitally, analog stages are still needed to get the data into the digital system, and often to get it back out as well.
I still design a lot of hobby projects using op-amps (many are posted on my web site), and I sometimes get comments like, "you could have done this using the [PIC/ATMEL/...] single-chip computer". I think that in a way, analog design is to digital design like using a slide rule or RPN calculator is to using a computer. To do analog design, you really need to understand the problem.
Stefan Vorkoetter
