Re: Double MEM module Message #2 Posted by Diego Diaz on 10 Nov 2008, 9:08 p.m., in response to message #1 by Daniel Diggelmann
Hi Daniel,
Seems that I'm the most appropriate to post a reply... :-)
Frist of all, thanks so much for your interest and contribution.
The Dual Memory modules are built by hardwiring line B4.
Facing the module connector B3 and B4 lines are the lower rightmost, being B4 the inner one.
One of the memory boards must have its B4 line tied to V+ while the other memory board must have it tied to GND.
V+ and GND are in the upper connector row, being GND on the left of B4 and V+ on its right (again facing the module connector).
Regarding the oppening method, I've been using a sharp nose pliers with good results during the past years.
Some PICS may also be heplful:
Insert the nose pliers on one connector slot end.
Apply gentle force to take both halves apart, and work the opposite end in the same way.
Most modules open with minimal or no damage at all.
Hope this helps.
Diego.
