Re: uWatch third batch now available Message #3 Posted by DaveJ on 2 Nov 2008, 3:34 p.m., in response to message #2 by Bruce Bergman
Anyhow, I spotted the belt clip attachment today. (!!) That might be exactly what I need! However, I don't see a link on your page for that attachment. Where do I get something like that? Is it available online? How sturdy is it?
The case is a Serpac C4, and it is available in the standard version as supplied with the uWatch, a belt clip version, and a key holder version. All in various colours and translucent types.
However I only carry the black standard one in stock, not many people have asked about the belt clip version.
You can get the belt clip attachment at
Digikey
You will however need to drill a small 2mm hold through the mounting stud and the clip.
How sturdy is it?
Hmm, how sturdy is your 5 minute epoxy? :->
The most vulnerable part would probably be the LCD screen, it doesn't have a protective sheet over it. You can even fill the underside of the LCD screen with potting resin material if you wanted to make it more robust overall.
The rear case with belt clip is held in place with just the one screw.
Dave.
