Re: OT: 36mm/1.4" wide thermal paper - where? Message #9 Posted by George Bailey (Bedford Falls) on 1 Nov 2008, 5:53 a.m., in response to message #8 by Marcus von Cube, Germany
Now I'm looking for a supplier of 36.5mm wide paper.
Maybe you should take a 20cm strip of fax paper and tailor it down with a photo cutter until it fits your printer, beginning from 36.9mm in 0.1mm steps, so you know exactly what width your printer needs.
And depending on how much you're planning to print, this DIY fax-paper-to-printer-paper-method might supply you with enough to just occasionally use the printer. If you have a real long metal ruler you'll be even able to cut 2m long strips off of the fax paper...
