HP-71b – best config ever Message #1 Posted by Roland Storz on 20 Oct 2008, 6:55 a.m.
Finally I found the time to combine all my bits and pieces to test working environment for my HP71 which includes:
• HP-71b (incl. HPIL, Math- and Forth Pack)
• Registered Emu71 by J.-F. Garnier
• HP-IL/PC Interface Card by Ch. Klug
• Older PC with ISA slot and windows 98
• JPCF01.BIN and RPNLEX
I’m totally enthusiastic, all that works perfectly together. As a basic HP71 environment you do not need anything more, at least I cannot imagine to TOP this.
I do hope this works till the end of my life.
Just one little issue where I’m a bit lost concerns the optimal procedure to set up the HPIL Loop.
During the start up I got several times the HPIL ERR messages: Loop broken or HPIL Device not found or Device not ready.
I tried several ways to set up and to find the optimal way, even the sequence of switching on devices, however, for me there seems no real logic behind. Sometimes it works immediately, sometimes not. I tried this little Basic Program SEND71 as well.
It works quite good to send from emu71 to HP71 but not vice versa.
Any idea to optimize?
Thanks in advance, Roland
