R/S key slightly slanted in 35s Message #1 Posted by Luis Moreno on 5 Oct 2008, 6:05 a.m.
Hi guys,
I have noticed that the R/S key in my new HP 35s is slightly slanted to the rigth side. It is not very noticeable unless you stare at. However, If I touch its surface, comparing with the adjacent GTO key, it is a bit more depressed and certainly sloped to the lower right side.
Could you please check that in your machines so as to know if it's an isolated case or if it's a common fabrication issue in this model?
Thanks,
