Re: Updates for i41cxp and 12C Classic for iPhone now available Message #22 Posted by Les Wright on 3 Oct 2008, 10:17 p.m., in response to message #21 by Eric Smith
True. You can load and CAT 2 their function listings, but apart from the HP67 porting functions in CARD-RDR I don't think they would be of much use.
I actually like to use some of the old HP67 programs with the 7xxxx commands, so CARD-RDR is useful. Unfortunately, the version in that directory is the pre-2007 version! The one that packs with V41 and that is downloadable elsewhere from TOS is the one the WF fixed in early 2007 when I noted that loading it V41 made the emulator to hang and act strangely in efforts to enter alpha info. Anthony will have WF correct this.
Anthony told me that he explicitly excluded modules from that list that won't work at all, like HEPAX, or are redundant, like XF/XM, XM and the various 41C memory modules. Maybe not vetted, but a little thought went into what to include and exclude. But I must admit that apart from CARD-RDR those other examples you give have no utility in i41cxp.
Les
