Re: 50G: calling Stat49Pro Message #9 Posted by Marcus von Cube, Germany on 19 Sept 2008, 4:08 a.m., in response to message #1 by Sancerre (Phoenix)
Tod,
I've played around a little and came to the following solution:
'ZALPHA(x)' does not work but you can embed the command in a program object:
<< -> x << x ZALPHA >> >> 'ZA' STO
Now, ZA is a function to be used in an algebraic expression.
