Re: HP50G Emulator Message #5 Posted by Dave on 18 Sept 2008, 4:01 p.m., in response to message #3 by Jan Kromhout
The default XP theme has really fat title bars. Just drag it up as far as you can past the top edge of your screen. If you can't drag it far enough, click the upper left corner, pick Move and use the arrow keys to move it as high as you need. Otherwise you'll have to create your own or modify the existing script and image as others have suggested, which is tedious.
