Re: Looking for old PPC Journal Program Message #2 Posted by Gerry Schultz on 5 Sept 2008, 6:19 p.m., in response to message #1 by Egan Ford
Egan:
I pulled up my HP-41 disk and went through the NOP columns of the PPC issues after V7N5, but I didn't see any corrections for the "PI to 10,000 Places" program. I did find in the "Further Reading" column of V8N2P4 where there is a graphical comparison of how long several different calculators took to calculate Pi to different decimal points.
I have a paper copy of V7N5 and I can mail to you a Xeroxed copy of the bar code, or I can scan it with my wand (if it still works) and send you a magnetic card (I have had my card reader fixed). I do have HP-IL and could run it through my HPIL to RS232C converter (I need to build a D-25 to D-9 cable and I have all the connector shells here at work) that I got recently but haven't used yet. Or, I can get really crazy and dig out my HPIL ISA card and put it in my old Pentium 233 and load up LIF(?) utilities and try to transfer the program that way, but I've never done that before. I bought the hardware but I haven't been motivated yet to learn how to do this. Now, I have a reason to play.
So, I'll try to scan the program into my 41 if my Wand works and save it off to cards. Then I can let you know if this will work. If someone else chimes in with a quicker solution for you, then I don't have to rush to get you a file.
Gerry
