Re: HP 25 schematics? IC pinouts? Message #2 Posted by Randy Sloyer on 29 Aug 2008, 4:55 p.m., in response to message #1 by Borja
I wouldn't be too optimistic it can be repaired... I've seen a lot of them in that state and 99% of the time it is a chip failure.
You should have a ~700khz semi-sine wave on pins 13 and 14 of the ACT IC, the 22 pin package. If you don't the chip is dead.
If the clock is running, look for a +5/-12 175khz system clock on pins 16 and 17.
It might be a bad rom (1818-0154) but I think you'll find the ACT is the problem. The only source will be from another 25. Some others from the 20 series may work but it's not a sure thing.
