Re: 17bii Battery Change Message #6 Posted by MikeO on 29 Aug 2008, 2:49 a.m., in response to message #1 by Brian H. (Houston)
Have the new batteries out and ready to insert.
I put the case in my hand, then slip the calculator face down into it, about 3/4 of the way in.
I found that using a paperclip to remove the batteries works well: slide on end alongside the battery stack and gently pull out with slight pressure on the side.
Then slip the new batteries in immediately.
Hope this helps.
MikeO
