HP Forum Archive 18
HP35s Flag10
Message #1 Posted by Hugh Clement on 3 Aug 2008, 6:29 p.m.
G'day evryone - I am trying to replace my old and faithful HP48GX with decent sized calculator - i am trailling the HP35s as I don't want to have the size of a HP50 and the old HP41CV was able to do all the programmes that a surveyor needs.
My problem is I can't find anywhere that tells you the keystrokes to set/clear flag 10 - when programming I can set flags 1-9 no problem but I can't get it to recognise double digits i.e. keystrokes of left shift - Flags - 1 (SF) - 10 results in A028 SF 1 A029 0
rather than A028 SF 10
If someone can point me in the right direction it would be good.
Also is there a book like William C Wickes - HP48 INSIGHTS (Part 1: Principles & Programming)
Re: HP35s Flag10
Message #2 Posted by Paul Dale on 3 Aug 2008, 6:33 p.m.,
in response to message #1 by Hugh Clement
try "SF . 0"
The decimal means 10 or higher.
- Pauli
Re: HP35s Flag10
Message #3 Posted by Karl Schneider on 3 Aug 2008, 9:18 p.m.,
Paul is right.
This "preceding decimal point" method of specifying indices 10-19 for flags and direct-access registers has been employed by HP for many years, going back at least to the HP-34C of 1979. However, it was never used on the higher-end models such as the HP-41, HP-42, and HP-48, since well over 19 of these resources were provided. Instead, the leading zero must be entered for indices less than 10.
-- KS
