Re: Displaying all roots of a number Message #2 Posted by Michael Andersson on 3 June 2008, 3:57 a.m., in response to message #1 by Hal Bitton in Boise
You should be able to use "PROOT" for this purpose. The command gives all the roots of an arbitrary polynomial and by transforming your problem into a plynomial equaton by setting the coefficient you don't need to zero you can find the roots.
For example to find all the fifth roots to 2+3i transform this into the equation -z^5+(2+3i)=0, on the 50g put
[ -1 0 0 0 0 (2,3) ]
(where the zeros are the coefficients for z^4 down to z^1) on the stack and press PROOT (found under "NUM.SLV"/"POLY").
The results is (approximately):
(1.27 , 0.25)
(-0.88 , -0.95)
(0.15 , 1.28)
(0.63 , -1.13)
(-1.17 , 0.54)
Hope this works.
Michael
