HP Forum Archive 18
Shooting the engineers?
Message #1 Posted by Palmer O. Hanson, Jr. on 2 June 2008, 1:43 a.m.
Near the end of the recent thread "Some curious numbers from my HP-67" I commented
One wonders why the designers did that.
J. F. Garnier responded with
... We could call it a bug.
Joe Horn responded
Yes, the '67 can work with exponents up to 499 internally. That's what is happening here with the '67 statistics bug.
Joe added a reference which (I think) attributes the curious numbers to non-normalized numbers. That does not explain why the HP-27 provides an overflow indication while the HP-67 does not. I thought about that some more and then I remembered the old business philosophy from the MBA community
There comes a point in every program where you have to shoot the engineers and get into production.
which is attributed to General Richard H. Thompson, a former commander of the Army Materiel Command (Aviation Week and Space Technology, August 3, 1987). I thought about that some more and wondered if the application of that philosophy might not have been the basis for the release of the buggy HP-35S.
Palmer .
Re: Shooting the engineers?
Message #2 Posted by Joe Horn on 2 June 2008, 10:20 p.m.,
in response to message #1 by Palmer O. Hanson, Jr.
Actually, it does. Most HP calculators check for overflow at the end of each function's code. As I mentioned, the HP-67 is unique in that it normalizes numbers in the DISPLAY routine, not beforehand. That's why it catches things like X^2 overflows (because they are displayed) but not overflows that are not displayed. They thought that they could get away with it because running programs cycle the X register through the display routine after every program step (toggling it on and off every other step, but that's another topic). If I remember correctly, "storage arithmetic" can generate overflow errors because they thought of that ahead of time and ran the result through the display code before restoring X.
You are right about the reason that they never debugged the ROM: ROM masks (aka ROM images?) were terribly expensive to design and make back then, and the bug was not deemed serious enough to justify the cost of creating a whole new ROM mask. Better to just take it to market and make a cryptic note in the manual.
Mask ROM's
Message #3 Posted by DaveJ on 3 June 2008, 12:02 a.m.,
in response to message #2 by Joe Horn
That's something I don't understand about the new 35S. From what I understand it uses a mask ROM, and I've wondered why.
I fully understand the price difference between a mask ROM part and a flash part, and it's importance to a cost sensitive consumer market. But this is not a $10 calculator, so it's not *that* much of a price difference in reality, one that could potentially be outweighed by the benefits of having a FLASH ROM.
Perhaps the sole reason is that they were forced to by the exam requirement? which appears to be their main target market.
Anyone know for sure?
Dave.
Re: Mask ROM's
Message #4 Posted by Raymond Del Tondo on 3 June 2008, 4:07 a.m.,
in response to message #3 by DaveJ
> But this is not a $10 calculator...
I think from the production cost perspective, the 35s _is_ a $10 calculator.
Raymond
Re: Mask ROM's
Message #5 Posted by DaveJ on 3 June 2008, 4:23 a.m.,
in response to message #4 by Raymond Del Tondo
Most likely the manufacturing cost is around the $10 mark. But I suspect the use of a FLASH part with a small increase in the base manufacturing cost would not have adversly affected the sales or marketability . That's why I suspect there are other reasons which are a bigger driver for the use of a masked part.
Perhaps a question for someone to ask HP at the upcoming conference?
Dave.
Re: Mask ROM's
Message #6 Posted by Christoph Giesselink on 3 June 2008, 3:39 p.m.,
in response to message #5 by DaveJ
I agree with Dave in some parts. But IMHO the production costs of a 35S are much below $10.
Let us make another calculation, the FLASH version maybe 40 cent more expensive than the mask version and let us think that programming the FLASH in production costs another 10 cent, this makes totally a difference of 50 cent for one unit. Further let us think that they want to sell 1,000,000 pices. In my calculation 1,000,000 * $0.50 = $500,000! And this is for me a lot of money. Some if you may say, the price difference of 50 cent between the two versions is too much, then let the price difference be 10 cent. But 10 cent price difference still mean $100,000!
Next thinking, who should upgrade the firmware? I think no end user would spend about $50 for programmer and I haven't calculated the necessary connectors for the update in the calculator so far. So a repairman at HP should do the update? Sorry for the price of the working time, unpacking the calculator, opening it, flash it, reassemble it, test it and send it back to the user it's much cheaper sending a replace unit.
Any questions?
Christoph
Re: Mask ROM's
Message #7 Posted by DaveJ on 3 June 2008, 5:15 p.m.,
in response to message #6 by Christoph Giesselink
For sure, it's a lot of money.
I've designed lots of high volume electronics where I have to shave off 0.1cents on this component or that component etc, and it really does add up.
But the choice of FLASH or mask ROM is often a strategic decision rather than pure financial. Especially in complex software projects such as a high end programmable calculator, as you gain so much advantage with FLASH. It can be insurance against having to dump a whole bunch of stock of mask ROM chips should you find a problem at the last minute, enabling of warranty firmware fixes etc.
You can safely buy 1,000,000 FLASH parts and get your volume discount at any time, but committing to 1,000,000 mask ROM chips is a big and risky decision. Goof it once and you may have lost all your price difference.
Perhaps the 35S actually uses a factory programmed FLASH die instead of mask ROM, has anyone tried to verify?
Dave.
Re: Mask ROM's
Message #8 Posted by Eric Smith on 3 June 2008, 6:00 p.m.,
in response to message #7 by DaveJ
Using masked ROM parts doesn't require committing to anywhere near a million parts. GeneralPlus will make masked parts for you in quantities under 1000.
That's why they put the software through QA.
Any bugs remaining when it ships are likely to be fairly obscure and minor. Even if they have to replace some calculators due to a bug, it will only be a tiny fraction of the sales.
Re: Mask ROM's
Message #9 Posted by Eric Smith on 3 June 2008, 5:57 p.m.,
It uses a masked ROM because the dirt-cheap microcontrollers made by GeneralPlus (formerly SunPlus) don't have flash. A comparable microcontroller with flash would cost at least a dollar more. There's no mystery to it.
Yes, it is. It doesn't sound like you've ever been involved in design of high-volume consumer products. Every dollar more they spend on parts is either three dollars more that the consumer pays, or a dollar less profit for HP.
Re: Mask ROM's
Message #10 Posted by DaveJ on 3 June 2008, 6:53 p.m.,
in response to message #9 by Eric Smith
My money is on that they probably had no choice in the matter, to get the calc to meet the exam requirements probably dictated the choice of mask ROM, as it did for no serial connectivity.
Apart from that, I suspect they *could* have used a FLASH ROM if they made the strategic decision to do that. Would have been fun for us anyway. $5 more in the retail would have unlikely killed the product, esp considering that they admittedly went overboard in the assembly costs. Although if you have no easy way for the user to upload a new firmware (i.e. no I/O) then there would be little point catering for just us calc nuts.
BTW, yes I have designed high volume consumer electronics, I know about the margins. I've spent many a long hour trying to shave 0.1cents off this part and that, parts consolidation, DFM etc. Luckily my new job doesn't need that, I can over-indulge to my hearts content. I design Rolls Royces now!
Dave.
Edited: 3 June 2008, 7:09 p.m.
Re: Mask ROM's
Message #11 Posted by Eric Smith on 3 June 2008, 10:42 p.m.,
in response to message #10 by DaveJ
There's no NCEES requirement that the calculator not have flash memory. The requirement is that it not have any communications other than the keyboard and display.
Of course. And if there was a strategic decision that it had to be able to heat sandwiches, they could have built a microwave oven into it as well.
Fundamentally, the decision to leave out flash is almost certainly based on cost. What is the anticipated profit to HP if the calculator costs $X, with some probability of returns due to bugs factored in, vs. the anticipated profit to HP if the calculator costs $X+1.
And even if it did have flash, a major bug would probably still require them to provide exchanges, so the added cost of the flash might not gain them anything. The cost of dealing with an exchange is likely higher if they have to reflash an existing calculator rather than simply destroying it and sending out a new unit.
Having worked for companies making moderately high-volume consumer products, I have some knowledge of how these decisions get made, though no specific insight into HP's process since I haven't worked there.
Re: Mask ROM's
Message #12 Posted by DaveJ on 3 June 2008, 11:06 p.m.,
in response to message #11 by Eric Smith
If I told you about some of the weird decisions that have gone into some of the products I've had to design, you probably wouldn't believe me! - or just maybe you might...
Dave.
Re: Mask ROM's
Message #13 Posted by Eric Smith on 4 June 2008, 12:40 a.m.,
in response to message #12 by DaveJ
The worst knock-down drag-out fights I've seen between engineering and marketing were over the choice of LED indicators on a product, the text for the legends, and how they should be positioned on the front panel.
Re: Mask ROM's - 20B update
Message #14 Posted by DaveJ on 10 June 2008, 6:30 p.m.,
Well, what a difference a week or so makes. The new HP 20B may have turned this idea on it's head. It's a $40 calculator, $20 less than the 35S, and it uses an Atmel 32bit ARM7 processor with (presumably) 128KB internal FLASH program memory.
Dave.
Message #15 Posted by Eric Smith on 12 June 2008, 1:27 p.m.,
in response to message #14 by DaveJ
The Atmel processor is significantly more expensive than the GeneralPlus masked-ROM part, so this seems to show that HP does find some compelling benefits to using flash memory.
Message #16 Posted by DaveJ on 12 June 2008, 9:19 p.m.,
in response to message #15 by Eric Smith
Yes, that does seem to be the case. And to do that and still keep the price down on this unit is quite an achievement. They shaved a few cents off with the die version.
I suspect this new calc was a fair bit less expensive to manufacture than the 35S.
Dave.
Message #17 Posted by Eric Smith on 13 June 2008, 1:46 a.m.,
in response to message #16 by DaveJ
I think that's hard to say. The 20b doesn't have the 32K*8 SRAM chips of the 35s, but the processor is more expensive. There's probably little other cost difference in the electronics. Until I get my hands on one, I won't have any guess as to whether the rest of the package is likely to be any less costly to manufacture.
I'd think assembly with heat stakes would likely be less expensive than assembly with screws as the 35s has.
Message #18 Posted by Palmer O. Hanson, Jr. on 4 June 2008, 10:28 p.m.,
Thank you for the help.
You remember correctly. And the nice part about that feature is that (from page 83 of the manual) when the user clears the error
The storage registers all contain the values they held before the error-causing operation was attempted.
In the earlier thread I noted that the TI-66 offered the same feature in the statistics routines in response to an overflow input.
Finally, it's a curious coincidence that the statistics routines of the TI-59 (TI's answer to the HP-67) also had a bug.
Palmer
