Re: HP-17B II financial calculator drains batteries frequently Message #3 Posted by Eric Smith on 12 May 2008, 1:31 a.m., in response to message #2 by Katie Wasserman
If a CMOS chip has low leakage after manufacture, and the leakage suddenly goes up significantly at some later date, that's almost always a sign of ESD damage to the chip. When that's the cause, there's no fix other than replacing the chip.
The only other obvious possibility is that the chip got into an unusual state. Remove the batteries and leave them out for a
long time (weeks). If you're very lucky and the problem isn't ESD, that might fix it. But probably not.
