Re: HP-97 Printer repair Message #7 Posted by Randy Sloyer on 5 May 2008, 4:11 p.m., in response to message #6 by Karl-Ludwig Butte
I have done this both ways, both on and off the printer. There are two things you should consider before proceeding:
1) I find you will get a better result by removing the shaft.
2) With the fast solution, one slip and you can destroy the print head.
Complete disassembly instructions can be found in the 97 service manual on the Museum DVD.
