Re: Revisiting: Poking a value into address 4100 (NoV-32/HP-41) Message #3 Posted by Diego Diaz on 30 Apr 2008, 8:53 p.m., in response to message #1 by Geir Isene
Hi Geir,
Although some people might think the opposite way, I'm *not* the most authoritative person to respond this question... mostly because I have no idea of the supposed behavior of that POKE function.
Assuming it does what every other POKE I've ever seen does. It will fill the given address with the given contents... right?
Ok, then simply place an H'000 into H'4100 to turn RAM block 0 (zero) on, or H'001 to turn on block 1 (one).
Anyhow, I'll have to check de NoV-32 code to confirm if this will work into a running program, or you'll need to go to "stand by" (set PWO line Low) to physically achieve the block swapping. Should this was the case, chances are that NoV-32 internal code would have to be modified to get RAM block swapped "on the fly". Yes, if we reach that point I may well be the most auhoritative person for the job... (well... er... hope so ;-))
Best wishes.
Diego
