Re: Wallet Case For 12C? Message #4 Posted by Raymond Del Tondo on 24 Apr 2008, 6:13 p.m., in response to message #3 by Charles
Yes, but that's the original HP genuine leather case,
which basically is a slip case with a flap.
The case I meant is more like a desk calendar:
The calc stays 'inside' the bottom part of the case,
and if you want to use it, you just flip the upper part backwards, away from you.
Often seen on japanese calculators those days;-)
